I have a lot of networking issue till I disable STP on controller why STP is an Issue?
Re: I have a lot of networking issue till I disable STP on controller why STP is an Issue?
Please see the thread here:  http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Spanning-tree-setting/m-p/127115/highlight/true#M27297
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor II
are you using multiaple VLAN interfaces?
if yes you will need to disbale STP on controller and use it on a switch and I beleive it is recommend by Aruba.
Islam Zidan │ Professional Services Engineer | ACCP,ACMP,ACEAP,AWMP,CWSP,CWDP,CWNA,CCNP,HP ASE ,MCITP
If you Found My Post Helping you kindly Give KUDOS and if it solved your question Kindly hit Accept as a solution box.
