I have a question about my Aruba router. I have high speed internet 40MBit DSL.
When connected through the  router, my speed is <5MBit.what are the possible options i need to chank on this issue.
Re: I have a question about my Aruba router. I have high speed internet 40MBit DSL.
What model access point is it?
Do you see a lot of interference reported in the dashboard?
Is this 2.4 or 5?
Tim
Tim Cappalli | Aruba Security
Aruba
What model device do you have?   Many of the Remote APs have limited throughput numbers.
AMFX | ACCX | ACDX | ACMX
 RAP-5WN
Is it in tunnel or bridge mode?
Tim
reply options onboth the case.not sure how to check in it
is any options of that issue?
Occasional Contributor I
Make sure your AP has negotiated at least 100M full duplex on its uplink port.
You can check that by issuing this command on the CLI of the controller.
show ap debug port status ap-name "<AP NAME>"
Look at the Speed and Duplex column.
