I have a strange issue with my network config kindly help
  • 1.  I have a strange issue with my network config kindly help
    Posted Jun 22, 2014 04:41 PM
    as I'm new to aruba I was deploying Master-master standby and one local deployment everything went fine except one thing
    on the local controller I create Vlan 40 with IP 192.168.40.40 and I used it as teh controller IP and on all controllers I didn't create loobacks as I didn't understand in what may I need it and the strange thing is I type :
    on interface gig 1/1 I typed:
    switchport access vlan 40
    switch port mode access
    and on interface gig 1/2
    I typed :
    switchport mode trunk
    switch trunk allown VLAN all
    switch trunk vlan native 40
    now I connect nortel switch on each port in vlan 40 and my laptop in vlan 40 but it didn't ping at all it just a basic network config but t didn't ping
    notes:all ports are trusted.
    I used another Vlan for master local connectivity and it worked fine.
    now why it didn't ping which it just a normal setting?
  • 2.  RE: I have a strange issue with my network config kindly help
    Posted Jun 22, 2014 05:46 PM
    planner_plan,
    Make sure that the native vlan on the Nortel side is also 40.
  • 3.  RE: I have a strange issue with my network config kindly help
    Posted Jun 23, 2014 01:53 AM
    thanks I will try it
