I have the problem with a D-LINK DWA-160 Wireless card
I have  IAP-105 4 units in my office.
I configure name SSID 'HYNC' that security is WPA2-Personal.
I connect to ssid  'HYNC' that is 5 GHz (802.11a/n) by wi-fi card that is DWA-160 (USB 2.0 - 802.11b, 802.11a, 802.11g, 802.11n )and I found it is 130 Mbps sometime it is 54 Mbps.
I force my card wifi use 5 GHz (802.11a/n) only in Advance mode of wifi card.
However i found it is 54Mbps when i connect to ssid 'HYNC'. but  I test with the Proxim Orinoco 802.11a/b/g/n it connect 300 Mbps to same ssid.
help me please....
Re: I have the problem with a D-LINK DWA-160 Wireless card
Please check here:  http://www.amazon.com/review/R2MVJOZI911A8U/ref=cm_cr_pr_viewpnt#R2MVJOZI911A8U
