I need help converting cisco 2950 config for s1500024p
I have 40 offices we are replacing the switches in. All are Cisco 2950 24 port switches with the same config save for specific ip addresses and vlans. I have 40 new s1500-24p switches to configure. Is there an easy way to import the cisco config (attached). Or if someone is bored and wants to work it with me, I'd appreciate the help. I had hoped to work with an engineer at the Airheads conferance, but my boss was late on the approval.
Contributor II
Re: I need help converting cisco 2950 config for s1500024p
 Below is the rough conversion of config from Cisco to Aruba.
hostname netarubasw01
mgmt-user smith root
  Password: <type password here>
 Re-Type password: <confirm password>
clock timezone CST -6
clock summer-time CDT recurring   <first|last|1-4>
ip domain-name pmic.com
ip name-server 10.102.105.21
ip name-server 10.102.105.22
spanning-tree mode pvst
vlan 69
 interface-profile switching-profile SW-PROFILE-69
switchport-mode access
access-vlan 69
interface-profile pvst-port-profile PORTFAST
portfast
interface gigabitethernet 0/0/1
interface gigabitethernet 0/0/2
interface gigabitethernet 0/0/3
interface gigabitethernet 0/0/4
interface gigabitethernet 0/0/5
interface gigabitethernet 0/0/6
interface gigabitethernet 0/0/7
interface gigabitethernet 0/0/8
interface gigabitethernet 0/0/9
interface gigabitethernet 0/0/24
interface vlan 1
no ip address
shutdown
interface vlan 69
ip address 192.168.69.2 255.255.255.0
ip-profile
default-gateway 192.168.69.1
logging 10.161.0.100
snmp-server community BBBr3ad
snmp-server enable trap
snmp-server trap enable authenticationFailure
snmp-server trap enable warmStart
snmp-server trap enable linkDown
snmp-server trap enable linkUp
snmp-server trap enable coldStart
ntp server 10.53.53.254
Also, here is a guide that shows the different command equivalents.
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Mobility-Access-Switch-for-Cisco-Juniper-Engineers-Part-1-Basic/td-p/208839
Tim Cappalli | Aruba Security
Contributor II
Note:
1. Aruba configuration is based on profiles
     To alter port configuration, first creat the correponding profile
       [ view the list of profiles   by logging on to switch (config) #interface-profile ?
    Hence in above you see that:
     one profile is created to specificy the switchport details
    => interface-profile switching-profile SW-PROFILE-69
   Another profile is created to alter the STP properties (Since you are choosing PVST)
    => interface-profile pvst-port-profile PORTFAST
     [If you had choosed MSTP, then create 'interface-profile mstp-profile PORTFAST'
      and accordingly apply that mstp-profile under the port]
2. Instead of configuring indvidual ports, if they have lot of common config you can make use of 'interface-group' to make config simple & fast
For example: In above repetative interface/port config can be replaced as below
interface-group gigabitethernet VLAN69-PORTS
apply-to 0/0/1-0/0/9            <<<<<<<<<< This list you can alter based on which ports you want to target
Thank you both for your valuable assistance. It is greatly appreciated.
Another question. As I am running this as a basic switch, do I really need all the pre-configured ACLs?
Or can I either remove or disable them?
It's part of the default config. Many can't be removed.
