Occasional Contributor I
I need to add a generic account to my Guest SSid
When I access the controller via the GUI it's not self explanitory.
I need to add the user to use the Guest SSid
Any and all information will be greatly appreciated
Thank in advance
Re: I need to add a generic account to my Guest SSid
Will need way more information, are you using Instant or a Controller? Your Guest SSID, is it using some kind of captive portal? Are you using clearpass?
Jerrod Howard
Community Administrator
This might be what you are looking for, but we will need a little more from you if its not.
config>security>auth>servers>internal db
Airheads Community - The best place to Connect. Engage. and Learn.
