I need your help?
How to provision RAP via Internet ? are the anybody have the experiance can help us ?
Re: I need your help?
Hi;
You need configure the aruba controller for RAP. For make a rap by internet you only need from the ap/iap  config the controller ip the public ip of main building. From site of controller you need redirect the request to public ip and port UDP 4500 to controller. Other form is the controller in the DMZ ( this is the best practices).
Regards.
Angel De la Encarnacion
ACMP, ACCP, ACDX #544
Please refer to the following :
https://www.arubanetworks.com/assets/vrd/RAPVRD_version_8.pdf
