IAP 103, 105 and 275 compatibility with Aruba Controller
Dear All, my client bought about 75 Alcatel-Lucent IAPs which are made by Aruba (IAP 103, IAP 105 and IAP 275).
Because of several issues on virtual controller, we want to install a physical controller to manage all these IAPs.
My questions are:
1) What are the Aruba controllers compatible with this 3 kinds of IAPs ?
2) is there any requirement on the OS Level of the different IAPs ?
Thanks in advance
Re: IAP 103, 105 and 275 compatibility with Aruba Controller
Hi Ange,
All these IAP models can be manged by controller running minimum version 6.4.0.0.
Please check with your Alcatel rep before going for the conversion.
