Occasional Contributor I
IAP-103 radio 5GHz is down
I've a strange issue with two IAP-103, namely leds PWR ENET 5GHz are on and green, 2.4GHz is off, but SSID is visable only on 2.4
04:bd:88:c8:74:c7# show ap bss-table
Aruba AP BSS Table
bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t
04:bd:88:07:4c:70 test ?/? 192.168.99.12 g-HT ap 11/19/19 0 04:bd:88:c8:74:c7 0 1m:41s
On console I noticed this error:
sapd config ERR or radar found: setting wifi0 wrong channel 11 or country 578, vap mode 8
wifi0: Channel 11 cc=242 not found
What can be a problem?
Re: IAP-103 radio 5GHz is down
What version of IAP software is this?
What country code are you using?
6.4.4.4-4.2.3.1 but the same problem with previous software version which I used 6.4.3.1-4.2.0.1
NO (NORWAY) but, I changed it, in order to see if makes the difference.
I would contact TAC.  You could have a hardware issue.
You might be right, I checked 3 IAPs, and 3rd was okay.
Thx.
