IAP 105 - Chromecast not visilble
Small network with two IAP 105's.  I've been through the forums and pouring over the various suggested settings to no avail.
version 6.4.4.0-4.2.4
ARP Filtering - disabled
DLNA - enabled
DLNA media - enabled
chromecast - enabled
Googlecast - enabled
DIAL - enabled
Full configuration attached.  Any input appreciated.
Re: IAP 105 - Chromecast not visilble
Try turning off deny-inter-user-bridging.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
