Contributor I
IAP 105 Max Rules?
I have set up a IAP 105 as my VC for a 10 IAP network at a remote office. I have created a list of rules about 140 -160 rules. When I load the config on the IAP i get about 80 rules and then it wont let me add any more. Are there any limits to #of rules in the IAP's
TIA for replies
Contributor I
Re: IAP 105 Max Rules?
Anybody have the same expreience any Aruba guru's know the answer??
thanks
Contributor I
Just wanted to update the community about the IAP in case anybody sees the same issue the IAP is limited to 64 rules / ssid as per TAC
