Having issues with a guest WiFi network on a second VLAN (150), this started after a firmware update and I cannot figure this out; I'm thinking there is a bug. We have 5 IAP-105 devices plugged into 2 HP switches. Both switches are trunked allowing all vlans, APs are plugged into trunked ports as well. Our router is a juniper SRX, with a guest VLAN #150.
SRX Gateway: 192.168.10.1 (this is the DHCP server)
Switch#1 vlan interface: 192.168.10.5
Switch#2 vlan interface: 192.168.10.6
Client joins and obtains 192.168.10.120
Both switches can ping each other, as well as the gateway. Gateway can ping switches. The switches can also ping a wireless client joined to the guest network, as well as the guest ping the switches.
Here is where things get wierd. The client obtains a DHCP address from the gateway, but can not ping it or make external DNS queries. The gateway can't ping the client either. If I hardwire a laptop into the switch on vlan 150 I can ping the gateway as well as the switches and browse the internet. It's odd.
Previous version: 6.1.3.0-3.0.0
Current version: 6.2.1.0-3.3.0.2
Any ideas would be great! Thanks in advance.
