Frequent Contributor II
IAP-105 & Controller
i will buy Controller 3200 , and 25 AP-105
Thinking to buy them as IAP-105  not AP-105  , sothat i ncan convert what i need bto AP-105 ( softwrae re-image )  & have the ability to use Instant APs with out controller if needed
is this true ?  do i have any limitations is this idea  ?
Re: IAP-105 & Controller
& if So , why doesn't all use thsi method , instead of byuing AP-105 ?
IAP-105 will give both options   ( controller based & conytroller less )  with same cost ?
Some client really does it. :smileywink: and choose this option - it's giving them some flexibility in different deployments methods.
BUT..
  • It will do the installation part a bit longer - because u should convert all your iAP to AP...One by one.
  • InstantAP have reset button - and those units can be rested to factory defaults = from CAP back to iAP..
That's it. All the rest is the same.  :smileyvery-happy:
Just a small tip: In order to convert instant to controller environment - just make sure your controller AOS version is supporting it.
(This should only work with ArubaOS 6.1 and above)
Me.
Thanks alot , based on that i will but IAP not AP   :)
Actually. You don't need to convert one by one. Just form them into a cluster and then you can convert them all with a few clicks.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
yep - it's also a working method.
So you can convert a bunch of IAPs into Campus APs in one shot ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: IAP-105
Yes. That is correct.
Sent from my iPhone
Seth R. Fiermonti
Email: seth@hpe.com
Re: IAP-105
Good to know
Thank you
Victor Fabian
