IAP 105 & IAP 275 On same Network ?
It is possible to use IAP105 and IAP 275 on the same network and we have all AP on the instant config portal ?
thanks for your help.
Ben
Re: IAP 105 & IAP 275 On same Network ?
Yes, just be sure they're running the same code version before you join them.
Tim Cappalli | Aruba Security
