IAP-105's on 6.2.1.0 firmware and Bandwidth throttling doesn't seem to do anything.
Hey guys, I limit our bandwidth to 3000Kbps, but when doing speed test's while on this network I still get my full internet pipe 20Mbps.  Is there something I can check to find out why this isn't working?
Re: IAP-105's on 6.2.1.0 firmware and Bandwidth throttling doesn't seem to do anything.
Can you try decreasing that value to something lower like 300K and see what happens and then confirm it is getting applied :
test_iap# show  network TEST-NETWORK | include "Per-user Limit"
Per-user Limit:        :300 kbps
I was able to test it and it worked , I am using 6.2.1.0-3.4.0.1_39461
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I decreased it down to 500kps, but was still getting 20Mbps in my speedtest.net app
What IAPOS version do you have installed ?
Thank you
Victor Fabian
Version: 6.2.1.0-3.4.0.1_39461
Is that the "3.4.0.1" part of the version?
6.2.1.0-3.4.0.1_39461  it looks like a new update was released today too a now, 6.2.1.0-3.4.0.3_403346 - going to check and see what fixes where in the latest release..
That's correct
Thank you
Victor Fabian
