IAP-105 with IAP-93
  • 1.  IAP-105 with IAP-93
    Posted Apr 09, 2013 03:53 PM
    Hi All,
    I have a query regarding the maximum capacity of Virtual contoller. if we use IAP-105 then we can have 64 APs then if we use IAP-93 then we can have only 16 APs
    Am i right?
    If i have IAP-105 VC for example IAP-105 already has 30 APs then can we extend the network using 20 number of IAP-93 to IAP-105 which already has 30 APs?
    Is that possible in mixed environment?
    Thanks in advance.
  • 2.  RE: IAP-105 with IAP-93
    Posted Apr 09, 2013 07:04 PM
    no this enviroment of mixing APS 93 and AP 105 will reduce your cluster number to 16
    Aps 93 just support a cluster of 16 APS
    And if you have a cluster of 30 105 and you put in that cluster a iap 93 it will reduce the cluster to 16 so be careful...
    Cheers
    Carlos
  • 3.  RE: IAP-105 with IAP-93
    Posted May 09, 2013 12:10 PM
    Hi this apply for the quantity of customers by ap?
