IAP-105 won't connect to virtual controller
  • 1.  IAP-105 won't connect to virtual controller
    Posted Dec 12, 2014 10:48 AM
    I have a new IAP-105 AP and am currently running a virtual Instant AP on another 105. I currently have 46 AP's on the network. I plugged in the new IAP-105 into a POE port for a current working IAP to be sure that all the switch ports were setup properly. I get solid green power, flashing enet, and solid orange A/N and B/G/N lights. The AP does not show up listed in my controller interface. I consoled into the AP and did a factory reset to see what would happen. It is getting the correct IP address and gateway for the VLAN it's on. I just can't figure out why it doesn't find the controller or Vise Versa.
    I'm not sure that it matters.  I can ping the device from my workstation.  How can I verify that this really is an Instant 105 and not just a regular 105.  It has the same IAP-105 on the bottom that all my other devices have.  I hav enot tried to console into another device during boot up to compare the boot process, but here it is for the one that won't connect if that gives anyone some information.
    Any advice would be appreciated.
    APBoot 1.4.0.3 (build 37726)
    Built: 2013-03-21 at 20:13:41
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
          dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
          00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
          01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  0
    Booting OS partition 0
    Checking image @ 0xbf100000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (6243016 bytes)
    Loading .data @ 0x813f42d0 (32 bytes)
    Clearing .bss @ 0x813f42f0 (16 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing...........................................................
    Aruba Networks
    ArubaOS Version 6.3.1.4-4.0.0.5 (build 43022 / label #43022)
    Built by p4build@stan on 2014-04-03 at 12:27:03 PDT (gcc version 4.3.3)
    CPU Rev: aa
    71x CPU
    Flash variant: default
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 120576k/131072k available (1697k kernel code, 10404k reserved, 674k data, 5428k init, 0k highmem)
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=26309120
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ..........................
    Model: AP-10x
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    Net:   eth0
    Signer Cert OK
    Policy Cert OK
    ELF file is 32 bit
    Aruba Networks
    CPU Rev: aa
    71x CPU
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ..................................................................................................................................................................................................................................................................................................................................................................................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    .<6>lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
    Domain Name: arubanetworks.com
    No panic info available
    Check backup ENV.
    Testing TPM... Passed
    ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count    400
    AG7100: Max rx descriptor count    252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: 18:64:72:ce:d2:ff
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    no ap config...
    ag7100_ring_alloc Allocated 4800 at 0x80352000
    ag7100_ring_alloc Allocated 3024 at 0x80800000
    AG7100: cfg1 0xf cfg2 0x7014
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
    AG7100: pll reg 0x18050010: 0x110000  AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0xfffef
    AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
    Writing 4
    Ethernet uplink active. Becoming Mesh Portal
    AP xml model 39, num_radios 2 (jiffies 11614)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    election init: rand=15 HZ=500
    IAP client match init
    notify asap_mod 3g no present...
    Starting watchdog process...
    Getting an IP address...
    Dec 31 16:00:23 udhcpc[1086]: udhcpc (v0.9.9-pre) started
    Dec 31 16:00:23 udhcpc[1086]: send_discover: pkt num 0, secs 0
    Dec 31 16:00:23 udhcpc[1086]: Sending discover...
    Dec 31 16:00:23 udhcpc[1086]: send_selecting: pkt num 0, secs 0
    Dec 31 16:00:23 udhcpc[1086]: Sending select for 10.100.1.55...
    Dec 31 16:00:23 udhcpc[1086]: Lease of 10.100.1.55 obtained, lease time 691200
    Dec 31 16:00:23 udhcpc[1086]: DHCP OPT 43 deleted airwave config
    10.100.1.55 255.255.255.0 10.100.1.1
    Compressing all files in the /etc/httpd directory...
    ip_time_handler: Got ip and packets on bond0 Started master election 303-0, rand 16
    Adding bridge entry for magic vlan GW, ifindex 8451, 24:de:c6:c9:90:e4
    (00:00:28) !!! Init ---> Slave
    Starting Webserver
    bind: Transport endpoint is not connected
    NTP Server not saved in flash... using default
    ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_spectrum: Version 2.0.0
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    ath_attach: scn 86ce0280 sc 86840000 ah 80740000
    wifi0: Base BSSID 18:64:72:6d:2f:f8, 8 available BSSID(s)
    bond0 address=18:64:72:ce:d2:ff
    br0 address=18:64:72:ce:d2:ff
    wifi0: AP type AP-105, radio 0, max_bssids 8
    wifi0: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
    ath_attach: scn 85c00280 sc 85c20000 ah 85c40000
    wifi1: Base BSSID 18:64:72:6d:2f:f0, 8 available BSSID(s)
    wifi1: AP type AP-105, radio 1, max_bssids 8
    wifi1: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
    ath_ahb: 0.9.4.5 (Atheros/multi-bss)
    Starting FIPS KAT ... Completed FIPS KAT
    shutting down watchdog process (nanny will restart it)...
    Completed SW FIPS KAT test
           <<<<<       Welcome to the Access Point     >>>>>
    process `snmpd_sap' is using obsolete setsockopt SO_BSDCOMPAT
    asap_send_elected_master: sent successfully
    wait for stm to initialize over
    User:
  • 2.  RE: IAP-105 won't connect to virtual controller
    Posted Dec 12, 2014 01:08 PM
    The fact taht you see the above where it did the master election shows you that this is an IAP vs a campus AP. I do see that it was looking for an airwave server from DHCP option 43, but that shouldn't have affected it joining the cluster.
  • 3.  RE: IAP-105 won't connect to virtual controller
    Posted Dec 12, 2014 01:17 PM
    Thanks for the reply.  At least I know I'm working with the right equipment.
    Maybe I'll try plugging it directly into the same switch as the instant AP and see if that helps.  I couldn't find any options in the software to turn off discovery of new AP's, so I'm assuming that's not an option.
    I did not purchase any support licensing for this unit.  I don't see any sort of licening listed in the virtual controller that will only allow me to connect so many AP's.  I originally purchased this as a spare in case one went down and it's been sitting in a box for a year.  Thus, I didn't purchase a license for it.  Could that be the problem?
