IAP-134 With No External Antennas
Simple question.....
I have an IAP-134, but don't have any external antennas for it right now. If I deploy this in a closed office space, what is the expected RF coverage from the AP itself. I have brought it online and it broadcasts the Instant ESSID, so I know it has the ability to broadcast without the antennas, but how far?
Is it similar to a 105's internal radio performance or worse?
Thanks!
Michael Haring
ACMP, ACCP, BCNE, CCENT, Palo Alto ACE 7.0
Re: IAP-134 With No External Antennas
You barely get any RF.  Don't count on any.
Frequent Contributor II
It's a *very* bad idea to have no antenna's connected, it might damage the radio's over time.
It will give you some coverage because all of the RF-energy is being transfered to the antenna connectors, but don't expect it to go far (I'd say a couple of meters in the same room).
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
