EP
IAP 175 and Ant-90
Hello's
I'm looking to deploy IAP-175's with the Ant-90 antenna. Given that the 175 has 4 antenna's should I plan for "2" Ant-90 antenna's for every IAP-175 ?
thanks
Blue
Re: IAP 175 and Ant-90
It depends on how you are deploying your coverage.  The AP-ANT-90 is a downtilt omnidirectional antenna, so that means it is suitable for mounting 30 to 40 feet above in a warehouse where you need coverage on the floor.  It has two connectors, so you would only need a single AP-ANT-90 antenna for each band.  So if you only want 2.4ghz coverage, you will only need one AP-ANT-90 antenna.  If you want both 2.4ghz and 5ghz coverage, you will need two AP-ANT-90 antennas.  That is IF that is the antenna you need for that application...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Just to be extra clear....Colin is not saying that you can use one (1) ANT-90 and connect a pigtail to each radio  (leaving the other chain unconnected).
MIMO radios must have all chains connected.   So if you want dual band coverage, you need two (2) ANT-90s.
Also, ANT-90 is perfectly good higher than 30-40ft (10-15m).   In fact, the antenna was originally developed for seaport high mast lighting systems.  We have them deployed as high as 50 meters and they work great.
-cl
EP
Thanks for your responses. I guess I was mistaken and maybe more confused after both posts. I apologize if the next few questions are dumb.
From the Spec sheet, I understand that the antenna is a dual band antenna.   To quote the sheet  ".....The Aruba AP-ANT-90 is a dual-band, spatial diversity....." . Am I misunderstanding this? And if it is dual band and only has two connectors in different bands and MIMO radios must have all chains connected does this not also imply that I require two Ant-90's? I must be overthinking this or simply not getting it. Please advise.
Also, what If i do not desire dual band coverage? What If i only want 2.4Ghz? The implementation is a warehouse, 50ft tall hence  the question.
thanks again for your time and expertise,
Blue
Blue,
Both connectors are dual band.
-cl
EP
Thanks cl
So could I get one AP ant-90 and connect to Radio 0 and Radio 1? And does this not violate the "not all chains are connected?"
thanks,
Blue
no.
you need 2 ANT-90s.
connect both pigtails on one to the 2.4GHz radio.
connect both pigtails on the other to the 5GHz radio.
-cl
EP
Thanks for your quick response. Much appreciated.
Blue
