IAP-205 (JW212A)
We are going to purchase IAP-205.
New to this type of AP.
Need PDF of Configuration & Installation.
Can someone help to configure the same.
Thanks & Regards,
Shiju Chacko
Shiju Chacko
Re: IAP-205 (JW212A)
Here's the User Guide.
THere's also an "Airheads Tutorials & Training" playlist on YouTube which has many Aruba Instant Videos.
That should get you going.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
Regular Contributor I
The IAP videos on youtube are great.  I think it is a 14 part series.  I watched them all.  Very helpful.  Are you planning to use the AP as an IAP or a CAP?
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=18047
Colin Joseph
Aruba Customer Engineering
Thanks for installation guide, is there any configuration guide in PDF.
So that we easily configure by read the manual.
Thanks & Regards,
Shiju Chacko
Shiju Chacko
Can you share what is CAP?.
Planning to use as IAP. One as Controller and other as Client. Hope my answer is right.
Shiju Chacko
CAP = Campus AP an AP that would connect to an Aruba controller.  You can convert Instant APs (IAP) to regular APs if you have a controller to tunnel them to.
IAP does not need a controller it has a built in virtual controller.
