IAP-205 on a controller
Can I use an IAP-205 on a mobility controller like an AP-205 standard? I can't do it with AP wizard under "Configuration" section on controller and I don't know why.
Thank you.
Re: IAP-205 on a controller
You would need to convert the IAP first:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-do-I-convert-an-Aruba-Instant-AP-to-a-campus-AP/ta-p/178988
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I tried this way but I can't pairing with controller, 'cause it should contact over ac-ftp protocol (maybe firmware downloading for upgrade) ip address from controller but it can't finish his.
Do you know why it?
What ArubaOS version are you running on the controller, this needs to be a minimum of ArubaOS 6.4.1.0 to support the IAP205 model.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
I have 6.4.2.2 ArubaOS
Hi, are you seeing any error messages? Is this IAP local to the controller? Any firewalls possibly blocking traffic?
If you run the below (where XXXX is the MAC of the IAP) on the controller, do you see any errors?
#show log all | include XXXX
I can't see that. IAP until turn to AP, the conversion process fails because it search a firmware or someone else over ftp on controller.
Do you know how can I upgrade IAP firmware if is that the reason?
