IAP 205 with Hotspot manager and vouchers for guest access
Hi
I would like to have a wireless solution for the company using IAP205 with controller or controllerless. I need to have a prefessional hotspot manager (vouchers for guest access) as well.
I had used IAP105 but they dont have this feature. I appreciate any helpful direction to achieve the goal.
Thanks for your support.
Re: IAP 205 with Hotspot manager and vouchers for guest access
ClearPass is what you're looking for. You can accomplish this with controller or controllerless.
Tim Cappalli | Aruba Security
Thanks for the quick reply.
Clearpass is an addon or separate product? How it integrates with Aruba? I appreciate the details. Thanks again.
ClearPass in An Authentication server (Phisic or Virtual) , it contain a module Called ClearPass Guest , that permit the generation guest vocher without the need of the controleur .
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Thank you for the details.
So, i will redirect the guest control to the clearpass from the Aruba consol? Is there any solution from Aruba itself to handle this?
For Aruba AP with controller yes, you can use the build in Captive Portal and you can generate temporary user in the local data base
But for the IAP you can create Guest account manually, and of course you have to delete them manually too.
So honestly if you have many guest, you have to buy a Guest management Solution, but if you have you haven’t you can use the Instant AP built In captive portal.
Raouf CHAHBOUNE
ClearPass is a policy engine. Please work with your Aruba partner to design a solution.
you can also lease a cloud services
Raouf CHAHBOUNE
I would like to have an on-premise solution. clearpass has this?
yes ClearPass is an On Promise Policy Engine Appliance.
Raouf CHAHBOUNE
