IAP-205H Ethernet Ports
If I am using IAP-205H. can I use the available Ethernet ports for other services like data, voice.
Please share some guide or configuration.
Regular Contributor II
Re: IAP-205H Ethernet Ports
Yes. Check out the wired profiles section in the User Guide or see the below link to the web help:
http://www.arubanetworks.com/techdocs/Instant_422_WebHelp/InstantWebHelp.htm#UG_files/Wired_port_profile/Wired-Profile.htm%3FTocPath%3DInstant%2520Features%7CWired%2520Profiles%7C_____0
David
ACDX #98 | ACMP | ACCP
The IAP-205H in mode RAP (Remote AP) can I use too the available Ethernet ports for other services like data, voice.
I am testing the aruba wireless environment (controller 7005 and Access Point IAP-205H), in this test the IAP-205H is in RAP mode (Remote AP) where I can not activate E2 and E3 (interfaces E1 its up).
The controller is running version 8.1.
Is there any incompatibility between the IAP-205H to enable interfaces in RAP mode?
