IAP-215 Reset admin login
  • 1.  IAP-215 Reset admin login
    Posted May 23, 2018 01:17 AM
    Is there any way to reset the admin login using the console port? I was reading on line that the admin : forgetme! trick was disabled? is that true?
  • 2.  RE: IAP-215 Reset admin login
    MVP EXPERT
    Posted May 23, 2018 03:41 AM
    Unfortunately you cannot reset the password using a console port on an IAP. You will need to physically reset the IAP which in turn will erase the configuration.
    http://community.arubanetworks.com/t5/Controller-less-WLANs/Where-is-the-reset-button-on-the-IAP-and-how-do-I-reset-the-IAP/ta-p/180980
    Is it a single IAP password you need to reset or a cluster of them?
