IAP 215 not booting
Hi guys,
I have just bought 8 new Aruba IAP-215, unfortunately none of them are booting, they are stuck in a boot-cycle somehow.
I have tried connecting them to various PoE switches, PowerInjectors and changed cables.
Have anyone else experienced this before?
Thanks in advance.
Re: IAP 215 not booting
are you able to capture the console output of a bad AP ?
Hi.
Yes,I got the console:
pls see the enclosed.
/Yours
Hit <Enter> to stop autoboot:  0
Checking image @ 0xee000000
Invalid image format version: 0xffffffff
Checking image @ 0xeee00000
Copying image from 0xeee00000
[    0.000000] Aruba Networks
[    0.000000] ArubaOS Version 6.4.1.0 (build 43882 / label #43882)
[    0.000000] Built by p4build@cyprus on 2014-05-22 at 14:24:44 PDT (gcc version 4.5.1)
and then
Getting an IP address...
[    9.646832] ADDRCONF(NETDEV_UP): bond0: link is not ready
[   15.657878] PHY: bond0 (mdio@ffe24000:00) - Link is Up - 1000/Full
[   15.731956] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
10.1.67.156 255.255.255.0 10.1.67.1
Running ADP...cat: /tmp/master: No such file or directory
Done. Master is
killall: nanny: no process killed
killall: sapd: no process killed
Sending SIGKILL to all processes.
Please stand by while rebooting the system.
[  108.907958] Restarting system.
there are a couple of things here... The AP is booting on Arbua OS 6.4.1.0 fom the 2nd partition due to the first being corrupt (not a big deal). But, the fact that the 2nd partition is ArubaOS 'regular' and not an IAP build suggests to me that your AP is an campus AP not an iAP.
the AP boots and then searches for a controller, which it does not find, so it reboots.
Can you flip one over and check that the sticker on the back says iAP-215 and not AP-215 ?
-dugem
Hi.
Just after I posted the last post, I figured the IAP/AP out myself (tnx to Mr. Google).
It is all just a AP-215 so we wrote the dealer, why he sended the wrong types.
Thank you for your support.
/Yours
