IAP-215 vs IAP-315
for medium density environment, which AP is better (215 vs 315) and why ?
Re: IAP-215 vs IAP-315
Go for the 315. Newer hardware. Longer support. Higher potential throughput.
The 210 series is nearing end of sale (Feb 2018) Edit: the campus version is anyway.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
rzz
Contributor II
wave two access points are inclined for things like mu mimo for better performance
rzz
Contributor II
