IAP 225 - Captive portal for wired clients
Hi Folks,
as we know, it's possible to set up an IAP225 for authentication using a captive portal for wireless clients. As far as I understood this is performed using NAT to the IAPs wired IP address.
Now we want to add this authentication capability to wired clients using the IAP's ENET1 interface.
As we have seen through some testing, the IAP seems to be bridging ENET0 to ENET1, so it seems to be impossible with the current setup.
Does one of you know how to achieve this? Perhaps just using one physical wired interface consisting of two logical ones (VLAN interfaces)?
