IAP-225 Issue
  • 1.  IAP-225 Issue
    Posted Mar 24, 2014 06:46 PM
    We have an IAP225 setup and running, however on at least 5 occasions now the AP appears to be working - can connect to UI and it appears to be broadcasting, however no client can connect to it regardless of the ssid used (wpa2 with a key and wpa2 enterprise). I have cold booted the device which seems to fix it, I havent had a real chance to look into it further as I have an office full of users who need to connect.
    Code is 6.3.1.2-4.0.0.3_41784.
    Has anyone expierienced anything similar?
    I will raise a case later on.
    Cheers
  • 2.  RE: IAP-225 Issue
    Posted Mar 24, 2014 09:24 PM
    Have you tried upgrading to 4.0.0.4 ?
    I am currently using that version and authenticating users with 802.1X with no issues.
  • 3.  RE: IAP-225 Issue
    Posted Mar 24, 2014 09:28 PM
    I am planning on it this afternoon.
    It does work - for a while, then it stops working.
  • 4.  RE: IAP-225 Issue
    Posted Mar 24, 2014 11:10 PM
    I had the same issue when I first gotten my IAP 225 after the upgrade it works fines.
