IAP 225 and mounting brackets Product Code
Hi there,
I am trying to order IAP225 and mounting bracket for ceiling tile rail. I will need to order some mounting brackets (some of the ones that cme with the AP for ceiling tile rail) as a site I am looking after has 3 IAPs above the ceiling and I want them installed below on the rail.
Also, I am looking at the product codes and they only seem to be in;
JW240A Aruba Instant IAP-225 (RW) 802.11n/ac Dual 3x3:3 Radio Integrated Antenna AP
JW242A Aruba Instant IAP-225 (US) 802.11n/ac Dual 3x3:3 Radio Integrated Antenna AP
JW239A Aruba Instant IAP-225 (JP) 802.11n/ac Dual 3x3:3 Radio Integrated Antenna AP
JW238A Aruba Instant IAP-225 (IL) 802.11n/ac Dual 3x3:3 Radio Integrated Antenna AP
I dont see the code for Ireland, can anyone help with above please it will be much appreciated.
Kind Regards
Re: IAP 225 and mounting brackets Product Code
@prodigy wrote:
Hi there,
Kind Regards
For Ireland, the rest-of-world product code is appropriate.
Charlie Clemmer
Aruba Customer Engineering
Many thanks for your response that cleared that up. On that note; would you also know the code for License to have the 4 IAP225s on Aruba Central..? Also 3 year subscription Key.
Kindest Regards and thanks again.
Also, mounting bracket codes for ceiling tile rail..?
I am so sorry I mean 5 year license
Sorry about that.
Looking forward to hearing from you
Ceiling tile rails should be included with the AP.
For Central pricing, I would contact a local HPE/Aruba partner in your area who has the correct product skus and pricing.
Charlie Clemmer
