IAP-228 Radios disabled - LLDP/POE Issue
Hello everyone,
I am facing an issue for few weeks :
My IAP-228 are connected to a Aruba 2530 Non-POE and a HP 2520 POE, through a POE+ Injector
Sometimes after a reboot, the IAP-228 disabled their radios.
I found the following logs in show tech :
"Power Supply                : POE-AF
LLDP Power                  : 0.0W
Current Operational State   : Ethernet port 1 disabled; All radios disabled;"
[  134.627885] Fri Jun  9 07:35:25 2017:61         68.952064 K2 radio 0 reject VAP creating for 11AF power
[  134.649555] Fri Jun  9 07:35:25 2017:62         68.973734 K2 radio 1 reject VAP creating for 11AF power
[  134.671742] Fri Jun  9 07:35:25 2017:63         68.995923 K2 radio 0 reject VAP creating for 11AF power
[  134.746840] Fri Jun  9 07:35:25 2017:64         69.071021 K2 radio 0 reject VAP creating for 11AF power
[  134.768199] Fri Jun  9 07:35:25 2017:65         69.092379 K2 radio 1 reject VAP creating for 11AF power
[  134.789054] Fri Jun  9 07:35:25 2017:66         69.113235 K2 radio 0 reject VAP creating for 11AF power
[  134.810716] Fri Jun  9 07:35:25 2017:67         69.134897 K2 radio 1 reject VAP creating for 11AF power
[  134.831979] Fri Jun  9 07:35:25 2017:68         69.156159 K2 radio 0 reject VAP creating for 11AF power
[  134.852968] Fri Jun  9 07:35:25 2017:69         69.177149 K2 radio 1 reject VAP creating for 11AF power
[  134.874710] Fri Jun  9 07:35:25 2017:70         69.198891 K2 radio 0 reject VAP creating for 11AF power
[  134.895946] Fri Jun  9 07:35:25 2017:71         69.220127 K2 radio 1 reject VAP creating for 11AF power
Jun  9 09:36:01  sapd[3398]: <311020> <ERRS> |AP Borne_11@10.200.0.22 sapd|  An internal system error has occurred at file sapd_instant.c function send_pwr_status_to_stm line 3121 error send_pwr_status_to_stm: fail to get aruba101 bssid.
Jun  9 09:36:01  sapd[3398]: <311020> <ERRS> |AP Borne_11@10.200.0.22 sapd|  An internal system error has occurred at file sapd_instant.c function send_pwr_status_to_stm line 3121 error send_pwr_status_to_stm: fail to get aruba102 bssid.
Jun  9 09:36:02  sapd[3398]: <311020> <ERRS> |AP Borne_11@10.200.0.22 sapd|  An internal system error has occurred at file sapd_instant.c function send_pwr_status_to_stm line 3121 error send_pwr_status_to_stm: fail to get aruba103 bssid.
I already had this issue, and the only workaround I found is to reboot the IAP until it boots correctly and then the LLDP negociated correctly (which it seems to be required for an 802.11af power).
The switches and IAPs are running last firmware image :
IAP:
ArubaOS (MODEL: 228), Version 6.5.3.0
Website: http://www.arubanetworks.com
(c) Copyright 2017 Hewlett Packard Enterprise Development LP.
Compiled on 2017-05-24 at 22:08:47 AST (build 59775) by p4build
FIPS Mode :disabled
HP 2520 :
Image stamp:    /ws/swbuildm/rel_hartford_qaoff/code/build/elmo(rel_hartford_qaoff)
                Apr 13 2017 15:49:56
                S.15.09.0029
                66
Boot Image:     Primary
Aruba 2530 :
Image stamp:    /ws/swbuildm/rel_tacoma_qaoff/code/build/lakes(swbuildm_rel_tacoma_qaoff_rel_tacoma)
                Apr 14 2017 12:48:22
                YA.16.03.0004
                223
Boot Image:     Primary
Boot ROM Version:    YA.15.19
Pretty strange, espacially I have other IAP-228 on other Aruba/Procurve switches which are running fine without any problem.
I already checked cables
Anyone is facing the same issue?
Is there any way to disable this negotiation process, or at least for not disabling radios?
Does anyone know a reliable workaround?
Cheers!
Jeremy
Re: IAP-228 Radios disabled - LLDP/POE Issue
Bump
Might be a long shot but have you enabled MAS Integration on the IAP? Does this make a difference? I believe it enables extra TLV's for LLDP.
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
I didn't know this setting, I tested and it doesn't seem to work better.
Anyway thanks for your reply
Hi everyone,
I just upgraded from 6.5.3.0 to 6.5.4.2 and it seems to have fixed my issue... a little bit strange because I didn't find anything related to PoE or AP-228...
Hi everyone,
I have the same issue with release 6.5.4.4_62887
Please be specific what equipment and configuration you are using.
Colin Joseph
Aruba Customer Engineering
