Contributor I
IAP 275
How many clients can IAP 275 support ? and how much area of coverage does IAP 275 have ?
Re: IAP 275
The most clients an IAP 275 will support is 255.  For coverage, it depends on the antenna.  Please see the outdoor VRD here  http://community.arubanetworks.com/t5/Validated-Reference-Design/Outdoor-MIMO-Wireless-Networks/ta-p/155624  for more details.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: IAP 275
Functional radius of coverage should be considered to be 100-200m with clear line of sight, depending on the applications, client device, and performance requirements. Max client suport is 255, however, again the client devices and applications will dictate functional limits.
Jerrod Howard
