May I ask you for help?
I have two problems:
1) problem with Walled Garden on Aruba Instant (IAP-305 firmware 6.5.3.1_60333). If I create some domains in whitelist then IAP redirect to captive portal (always). Whitelist doesn't work.
2) problem with CNA (Captive Network Assistant) on the same captive portal (internal instant captive portal). CNA doesn't work on apple devices. Android devices working fine. The same model IAP and firmware.
Do you have some idea?
Thanks & best regads,
Jan Masin.
