IAP 305 and IAP 275
Is it possible to have IAP 305s and IAP 275s in the same cluster?
Will they run on the same image?
Kind Regards,
Rieyaad
Re: IAP 305 and IAP 275
Yes
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
