IAP-314 Antenna Cable Connection to D100 4X4 OUTDOOR MIMO ANTENNA Q8N50A
We are going to install IAP-314 which has Four Antenna (ANT0,1,2 & 3), which will be connected to D100 4X4 OUTDOOR MIMO ANTENNA Part#Q8N50A.
This Antena has four ports (-45 ,  +45 , V & H).
I would like to know is there a specific way that these Antenna ports from IAP 314 (ANT0,1,2 & 3) connect to particular ports on Outdoor Antenna box ports (-45 ,  +45 , V & H)?
Regular Contributor I
Re: IAP-314 Antenna Cable Connection to D100 4X4 OUTDOOR MIMO ANTENNA Q8N50A
Should not matter. For Beam forming or anything else the AP will measure the signal it sees on each connection, it does not matter which order they are plugged in.
ACDX, ACCP, CISSP, CWNA
Note, beamforming is not very effective when using directional antennas, just an FYI.
Jerrod Howard
