IAP 325 Management vlan / ip
I am bit confused with this configuration here on IAP 325.
How do I assigne static ip to management network / vlan. I would like management ip to be part of management vlan that we have created.
And client wireless traffic to flow through another vlan.
Re: IAP 325 Management vlan / ip
By default, an IAP gets its management ip address from the untagged VLAN that it is on via DHCP.  You can edit the IAP and make the ip address static.  The instructions at the link are for if you want the managment VLAN to be on a tagged VLAN on a trunk port.  This is separate from setting a static ip address.
Colin Joseph
Aruba Customer Engineering
