Super Contributor II
IAP-325 and Link Aggregation
I found this article regarding link aggregation on the IAP-325.
Since the IAP-325 comes with 2x1GB ethernet ports, does this mean that we can create a link aggregation/port channel back to our Cisco switch to provide a 2 GB link for the traffic coming from the AP?
Cheers
Re: IAP-325 and Link Aggregation
Yep. From the AP325 datasheet:
"Link Aggregation support to achieve platform throughput up to 2 Gbps"
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
Sorry, I missed that!
Thank you for confirming!
Cheers
