Occasional Contributor I
IAP-335 and IAP-345 in same instant cluster, possible (which FW)?
Hi
We are running a cluster of IAP-335 Instant APs.
We now want to buy the new IAP-345 devices and run them in the same instant cluster.
Is this possible and what common firmware level should we run (i know that with IAP-105 and IAP-335 it was not possible)?
Best,
Thomas
Re: IAP-335 and IAP-345 in same instant cluster, possible (which FW)?
You will need to run a minimum of InstantOS 8.3.0.0 in this environment as this is the earliest release supported by the IAP-345.
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
