IAP 93 Virtual Controller and Guest network
I'm new to Aurba but we just purchased a few Aurba IAP 93 access points to play with.  I was setting up a guest network and letting the virtual controller assign the vlan.  It was giving out 172.16.x.x ip addresses.  Then I took the firmware upgrade.  Now the guest vlan gives out 192.168.x.x ip addresses.  Is there anyway to change that back to 172.16.x.x.?
Retired Employee
Re: IAP 93 Virtual Controller and Guest network
IAP does not have an option to change the private subnet that is assigned, but it will select a subnet that is not currently used on the network.
