Frequent Contributor I
IAP Integration with ISE
Hi Guys,
I am stucked on something that is beyond my head now. I have a simple lab setup with:
- Aruba IAP 115 running Version 6.5.3.0
- Cisco 3750 switch running IOS 12.2(55)SE11 (also configured as DHCP server)
- CPPM on version 6.6.0.81015 (Integrated with AD)
- Cisco ISE on version 2.3.x (Integrated with AD)
- Microsoft AD based on Server 2012
IAP has been configured with Corporate SSID (802.1x). Intention is to have a policy if a user belongs to AD group "Normal", he will be assigned a user role normal_user/VLAN 50 and if the user belongs to AD group "VIP", he will be assigned the role vip_user/VLAN30.
This is working as anticipated if I integrate ClearPass with IAP. Users get proper role and VLAN based on group membership.
For some odd reason this is not working if I integrate IAP with ISE.
I can see user being authenticated successfully. ISE is passing proper VLAN and user role back to IAP.
Client disconnects as soon as authentication completes. On IAP, I can see user session with proper role. But for some strange reason, client disconnects as soon as authenticaion completes.
I would rule out IAP config or client issue as same setup works perfectly fine if I use CPPM as authenticaion server instead of ISE.
Any thoughts?
Below are outputs for IAP and ISE:
 6/7/2017 21:48:17 PM    Target: Jibran-Test-IAP    Command: show clients
Client List
Name  IP Address  MAC Address        OS  ESSID      Access Point     Channel  Type  Role         IPv6 Address  Signal   Speed (mbps)
      0.0.0.0    14:a5:1a:0e:c4:78      Corporate  Jibran-Test-IAP  11       GN    vip_user     --            0(poor)  0(poor)
      0.0.0.0     ec:9b:f3:3e:ee:aa      Corporate  Jibran-Test-IAP  11       GN    normal_user  --            0(poor)  0(poor)
Number of Clients   :2
Info timestamp      :342088
 12304Extracted EAP-Response containing PEAP challenge-response
 11808Extracted EAP-Response containing EAP-MSCHAP challenge-response for inner method and accepting EAP-MSCHAP as negotiated
 15041Evaluating Identity Policy
 15006Matched Default Rule
 15013Selected Identity Source - Jibran-AD
 24430Authenticating user against Active Directory - Jibran-AD
 24325Resolving identity - vip_user
 24313Search for matching accounts at join point - jibran.local
 24319Single matching account found in forest - jibran.local
 24323Identity resolution detected single matching account
 24343RPC Logon request succeeded - vip_user@jibran.local
 24402User authentication against Active Directory succeeded - Jibran-AD
 22037Authentication Passed
 11824EAP-MSCHAP authentication attempt passed
 12305Prepared EAP-Request with another PEAP challenge
 11006Returned RADIUS Access-Challenge
 11001Received RADIUS Access-Request
 11018RADIUS is re-using an existing session
 11810Extracted EAP-Response for inner method containing MSCHAP challenge-response
 11814Inner EAP-MSCHAP authentication succeeded
 11519Prepared EAP-Success for inner EAP method
 12314PEAP inner method finished successfully
 24423ISE has not been able to confirm previous successful machine authentication
 15036Evaluating Authorization Policy
 24432Looking up user in Active Directory - Jibran-AD
 24355LDAP fetch succeeded - jibran.local
 24416User's Groups retrieval from Active Directory succeeded - Jibran-AD
 24420User's Attributes retrieval from Active Directory succeeded - Jibran-AD
 15048Queried PIP - Jibran-AD.ExternalGroups
 15004Matched rule - Aruba Vip User
 15016Selected Authorization Profile - aruba_vip_user,PermitAccess
 12306PEAP authentication succeeded
 11503Prepared EAP-Success
 11002Returned RADIUS Access-Accept
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
Re: IAP Integration with ISE
What radius attributes are you returning to set the role and VLAN?
Also you should manually disconnect the IAP user after you make each change on the ISE side to ensure that old settings are not being reused...
http://community.arubanetworks.com/t5/Controllerless-Networks/How-to-force-disconnect-a-client-in-Aruba-Central/td-p/294466
Hi Colin,
Yes I have tried manually disconnecting the user but result remains the same.
The attributes I am returnign are Aruba-user-role and Aruba-user-VLAN:
For Normal User:
Access Type = ACCESS_ACCEPT
Aruba-User-Role = normal_user
Aruba-User-Vlan = 50
For VIP User:
Aruba-User-Role = vip_user
Aruba-User-Vlan = 30
JayBee
Returning same attributes via CPPM and works fine:
Radius:Aruba:Aruba-User-Rolenormal_user
Radius:Aruba:Aruba-User-Vlan50
Radius:Aruba:Aruba-User-Rolevip_user
Radius:Aruba:Aruba-User-Vlan30
JayBee
Please try debugging the client connection by using the commands in the thread here. http://community.arubanetworks.com/t5/Controllerless-Networks/Troubleshooting-user-connectivity-issues-on-Instant-AP/m-p/79610/highlight/true#M1969
Hi Colin,
Could not find anything unusual except name=null.
Please find attached.
JayBee
What is the Mac address of the client?
Its 14:a5:1a:0e:c4:78
JayBee
It says that your radius server is rejecting the client:
Jun  7 22:17:44  stm[2633]: <132207> <ERRS> |AP Jibran-Test-IAP@20.0.0.4 stm|  RADIUS reject for station normal_user 14:a5:1a:0e:c4:78 from server CiscoISE.
Jun  7 22:17:44  stm[2633]: <132053> <ERRS> |AP Jibran-Test-IAP@20.0.0.4 stm|  Dropping the radius packet for Station 14:a5:1a:0e:c4:78 18:64:72:9c:ce:31 doing 802.1x
Jun  7 22:17:44  cli[2608]: <541003> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  Client 14:a5:1a:0e:c4:78 is failed to authenticate, failure count is 1.
Jun  7 22:17:46  stm[2633]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='14:a5:1a:0e:c4:78'
May be that is a typo while entering the password. Cannot see same error on subsequent attempts. Please refer to logs after manually disconecting user @ 23:05:38:
 6/7/2017 23:06:18 PM    Target: Jibran-Test-IAP    Command: show log debug
Jun  7 22:51:42  stm[2633]: __HIGHER_PRECEDENCE_COMPARE: 1110: matched_rule_index=30008, sap_sta->acl_rule_index=0, precedence_result=1
Jun  7 22:51:42  stm[2633]: stm_send_sta_update: Sending sta update msg to CLI0, mac='14:a5:1a:0e:c4:78'
Jun  7 22:51:42  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_stm_sta_update: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
Jun  7 22:51:42  stm[2633]: stm_start_acct_for_post_1xauth_user: 18218: ip not ready for sta '14:a5:1a:0e:c4:78'
Jun  7 22:51:42  stm[2633]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='14:a5:1a:0e:c4:78'
Jun  7 22:51:42  stm[2633]: sap_sta_mac_ppsk_timer_start: 17521: mac ppsk timer start
Jun  7 22:51:42  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_offline: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
Jun  7 22:51:42  sapd[2627]: sapd_proc_stm_reset_key: Got STM Reset key bss=18:64:72:9c:ce:31 mac=14:a5:1a:0e:c4:78, idx=0
Jun  7 22:52:00  syslog: main, 2755: opcode is show
Jun  7 22:52:03  mini_httpd[10298]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
Jun  7 22:52:03  mini_httpd[10299]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
Jun  7 22:52:05  syslog: main, 2755: opcode is show
Jun  7 22:52:15  syslog: main, 2755: opcode is support
Jun  7 22:52:15  syslog: process_msg_ref: 22: got msg_ref of len 9750 and body '/tmp/.cli_msg_66Sjmd'
Jun  7 22:52:15  syslog: process_msg_ref: 47: opening '/tmp/.cli_msg_66Sjmd'
Jun  7 22:52:15  syslog: process_msg_ref: 52: reading large msg
Jun  7 22:52:15  syslog: process_msg_ref: 55: read large msg of 9749 bytes
Jun  7 22:52:30  syslog: main, 2755: opcode is show
Jun  7 22:53:16  rngd: read=768 bytes_read=0 size=2500
Jun  7 22:53:30  syslog: main, 2755: opcode is show
Jun  7 22:53:47  awc[2605]: isc_init: could not resolve 'device.arubanetworks.com'
Jun  7 22:53:47  awc[2605]: isc_init failed
Jun  7 22:54:00  syslog: main, 2755: opcode is show
Jun  7 22:54:21  rngd: read=768 bytes_read=768 size=2500
Jun  7 22:54:30  syslog: main, 2755: opcode is show
Jun  7 22:54:32  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_online: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:21 essid-Corporate.
Jun  7 22:54:32  stm[2633]: recv_radius_acct_multi_session_id: 18172: got mac='14:a5:1a:0e:c4:78', name='(null)', start_time='1496839142 (Wed Jun  7 22:39:02 2017 )'
Jun  7 22:54:32  sapd[2627]: sapd_proc_stm_reset_key: Got STM Reset key bss=18:64:72:9c:ce:21 mac=14:a5:1a:0e:c4:78, idx=0
Jun  7 22:54:32  sapd[2627]: <127038> <WARN> |AP Jibran-Test-IAP@20.0.0.4 sapd| |ids-ap| AP(18:64:72:9c:ce:20): Cleared Station Associated to Rogue AP: An AP is no longer detecting a client 14:a5:1a:0e:c4:78 associated to a rogue access point (BSSID 88:a6:c6:98:dc:c8 and SSID Cisco on CHANNEL 1).
Jun  7 22:54:32  stm[2633]: iap_fmt_called_station_id: Called Station ID Type is (0)
Jun  7 22:54:32  stm[2633]: iap_fmt_called_station_id: Called Station ID buffer is (186472c1cce2)
Jun  7 22:54:32  stm[2633]: __HIGHER_PRECEDENCE_COMPARE: 1110: matched_rule_index=30008, sap_sta->acl_rule_index=0, precedence_result=1
Jun  7 22:54:32  stm[2633]: stm_send_sta_update: Sending sta update msg to CLI0, mac='14:a5:1a:0e:c4:78'
Jun  7 22:54:32  stm[2633]: stm_start_acct_for_post_1xauth_user: 18218: ip not ready for sta '14:a5:1a:0e:c4:78'
Jun  7 22:54:32  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_stm_sta_update: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:21 essid-Corporate.
Jun  7 22:54:32  stm[2633]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='14:a5:1a:0e:c4:78'
Jun  7 22:54:32  stm[2633]: sap_sta_mac_ppsk_timer_start: 17521: mac ppsk timer start
Jun  7 22:54:32  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_offline: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:21 essid-Corporate.
Jun  7 22:54:59  syslog: main, 2755: opcode is show
Jun  7 22:55:26  rngd: read=768 bytes_read=1536 size=2500
Jun  7 22:55:29  syslog: main, 2755: opcode is show
Jun  7 22:56:29  syslog: main, 2755: opcode is show
Jun  7 22:56:31  rngd: read=768 bytes_read=2304 size=2500
Jun  7 22:56:31  rngd: 3072 bytes read from TPM
Jun  7 22:56:59  syslog: main, 2755: opcode is show
Jun  7 22:57:29  syslog: main, 2755: opcode is show
Jun  7 22:58:53  awc[2605]: isc_init: could not resolve 'device.arubanetworks.com'
Jun  7 22:58:53  awc[2605]: isc_init failed
Jun  7 22:59:00  syslog: main, 2755: opcode is show
Jun  7 23:00:00  syslog: main, 2755: opcode is show
Jun  7 23:01:30  syslog: main, 2755: opcode is show
Jun  7 23:03:00  syslog: main, 2755: opcode is show
Jun  7 23:03:55  awc[2605]: isc_init: could not resolve 'device.arubanetworks.com'
Jun  7 23:03:55  awc[2605]: isc_init failed
Jun  7 23:04:00  syslog: main, 2755: opcode is show
Jun  7 23:05:00  syslog: main, 2755: opcode is show
Jun  7 23:05:33  mini_httpd[11874]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
Jun  7 23:05:34  mini_httpd[11875]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
Jun  7 23:05:35  syslog: main, 2755: opcode is show
Jun  7 23:05:38  syslog: main, 2755: opcode is action
Jun  7 23:05:38  cli[2608]: <341101> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  Execute command-disconnect-user mac 14:a5:1a:0e:c4:78.
Jun  7 23:05:38  cli[2608]: <541023> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  disconnect_user,20713: del client 14:a5:1a:0e:c4:78, client count 0.
Jun  7 23:05:38  cli[2608]: <541026> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  disconnect_user: send disconnect user, AP ip: 20.0.0.4, client ip 30.0.0.7.
Jun  7 23:05:38  stm[2633]: handle_disconnect_user: 10055: Cannot find sta infor for sta '14:a5:1a:0e:c4:78'
Jun  7 23:05:39  syslog: main, 2755: opcode is show
Jun  7 23:05:44  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_online: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
a_online,1246: add client 14:a5:1a:0e:c4:78, client count 1.
Jun  7 23:05:44  stm[2633]: recv_radius_acct_multi_session_id: 18172: got mac='14:a5:1a:0e:c4:78', name='(null)', start_time='1496840743 (Wed Jun  7 23:05:43 2017 )'
Jun  7 23:05:44  sapd[2627]: sapd_proc_stm_reset_key: Got STM Reset key bss=18:64:72:9c:ce:31 mac=14:a5:1a:0e:c4:78, idx=0
Jun  7 23:05:44  stm[2633]: iap_fmt_called_station_id: Called Station ID Type is (0)
Jun  7 23:05:44  stm[2633]: iap_fmt_called_station_id: Called Station ID buffer is (186472c1cce2)
Jun  7 23:05:48  mini_httpd[11912]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
Jun  7 23:05:49  mini_httpd[11913]: handle_request: 2296: SSL_accept fail, child exit after 0 requests error state on socket
Jun  7 23:05:49  stm[2633]: iap_fmt_called_station_id: Called Station ID Type is (0)
Jun  7 23:05:49  stm[2633]: iap_fmt_called_station_id: Called Station ID buffer is (186472c1cce2)
Jun  7 23:05:49  stm[2633]: __HIGHER_PRECEDENCE_COMPARE: 1110: matched_rule_index=30008, sap_sta->acl_rule_index=0, precedence_result=1
Jun  7 23:05:49  stm[2633]: stm_send_sta_update: Sending sta update msg to CLI0, mac='14:a5:1a:0e:c4:78'
Jun  7 23:05:49  stm[2633]: stm_start_acct_for_post_1xauth_user: 18218: ip not ready for sta '14:a5:1a:0e:c4:78'
Jun  7 23:05:49  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_stm_sta_update: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
Jun  7 23:05:49  stm[2633]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='14:a5:1a:0e:c4:78'
Jun  7 23:05:49  stm[2633]: sap_sta_mac_ppsk_timer_start: 17521: mac ppsk timer start
Jun  7 23:05:49  cli[2608]: <541004> <WARN> |AP Jibran-Test-IAP@20.0.0.4 cli|  recv_sta_offline: receive station msg, mac-14:a5:1a:0e:c4:78 bssid-18:64:72:9c:ce:31 essid-Corporate.
Jun  7 23:05:49  sapd[2627]: sapd_proc_stm_reset_key: Got STM Reset key bss=18:64:72:9c:ce:31 mac=14:a5:1a:0e:c4:78, idx=0
Jun  7 23:05:53  syslog: main, 2755: opcode is show
Jun  7 23:06:17  syslog: main, 2755: opcode is support
JayBee
