IAP Log analysis help
Hello everyone,
I would like to get information about the following log detail:
Jun 11 14:15:28 10.1.50.216 cli[2934]: <341197> <DBUG> <10.1.50.216 x:x:x:x:x:x> Send heartbeat to vc 10.1.50.205, length 382.
Jun 11 14:15:28 10.1.50.216 cli[2934]: <341001> <DBUG> <10.1.50.216 x:x:x:x:x:x> recv recovery request from 10.1.50.205: recovery number:1.
Jun 11 14:15:28 10.1.50.216 cli[2934]: <341001> <DBUG> <10.1.50.216 x:x:x:x:x:x> recovery clients(1)
Jun 11 14:15:28 10.1.50.216 cli[2934]: <341001> <DBUG> <10.1.50.216 x:x:x:x:x:x> Recovery clients,1, request from 10.1.50.205.
Jun 11 14:15:28 10.1.50.216 cli[2934]: <341124> <DBUG> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: machine auth token client number-0.
Jun 11 14:15:28 10.1.50.216 cli[2934]: <541036> <INFO> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: send idle timeout, sta x:x:x:x:x:x , idle time-1000.
Jun 11 14:15:28 10.1.50.216 cli[2934]: <541058> <DBUG> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: Add calea state, Station x:x:x:x:x:x, intercept 0.
Jun 11 14:15:28 10.1.50.216 cli[2934]: <541056> <DBUG> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: Add auth state, Station x:x:x:x:x:x, authenticated 0.
Jun 11 14:15:28 10.1.50.216 cli[2934]: <341125> <DBUG> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: add reauth ctx client-1.
Jun 11 14:15:28 10.1.50.216 cli[2934]: <341001> <DBUG> <10.1.50.216 x:x:x:x:x:x> send recovery request to STM
Jun 11 14:15:28 10.1.50.216 <10.1.50.216 x:x:x:x:x:x> stm[2962]: recv recovery sta request 1.
Jun 11 14:15:38 10.1.50.216 cli[2934]: <341197> <DBUG> <10.1.50.216 x:x:x:x:x:x> Send heartbeat to vc 10.1.50.205, length 382.
Jun 11 14:15:38 10.1.50.216 cli[2934]: <341001> <DBUG> <10.1.50.216 x:x:x:x:x:x> recv recovery request from 10.1.50.205: recovery number:1.
Jun 11 14:15:38 10.1.50.216 cli[2934]: <341001> <DBUG> <10.1.50.216 x:x:x:x:x:x> recovery clients(1)
Jun 11 14:15:38 10.1.50.216 cli[2934]: <341001> <DBUG> <10.1.50.216 x:x:x:x:x:x> Recovery clients,1, request from 10.1.50.205.
Jun 11 14:15:38 10.1.50.216 cli[2934]: <341124> <DBUG> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: machine auth token client number-0.
Jun 11 14:15:38 10.1.50.216 cli[2934]: <541036> <INFO> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: send idle timeout, sta x:x:x:x:x:x , idle time-1000.
Jun 11 14:15:38 10.1.50.216 cli[2934]: <541058> <DBUG> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: Add calea state, Station x:x:x:x:x:x, intercept 0.
Jun 11 14:15:38 10.1.50.216 cli[2934]: <541056> <DBUG> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: Add auth state, Station x:x:x:x:x:x, authenticated 0.
Jun 11 14:15:38 10.1.50.216 cli[2934]: <341125> <DBUG> <10.1.50.216 x:x:x:x:x:x> send_part_sta_update: add reauth ctx client-1.
Jun 11 14:15:38 10.1.50.216 cli[2934]: <341001> <DBUG> <10.1.50.216 x:x:x:x:x:x> send recovery request to STM
x:x:x:x:x:x == Aruba Access Points MAC address
Anomalies often appear on the network. During that period, the client will be disconnected from the network.
Aruba OS version:
6.5.4.4_62887  (IAP Cluster)
Have you met similar?
What does the log detail mean?
Thank you very much for your help and information!
Re: IAP Log analysis help
Debug logs are meant for engineering and Aruba TAC to analyze.
Please work with your partner or Aruba TAC if you have an issue that is related to these logs.
