Occasional Contributor I
IAP Mgmt mode is changed from athena-mgmt to local-mgmt
I've been having a problem connecting to the Aruba upgrade server since a firmware update.   In troubleshooting it, I accidentally set the mgmt mode to local-mgmt but I don't know how to change it back.  Can someone tell me how to do this, please?
Thanks!
Re: IAP Mgmt mode is changed from athena-mgmt to local-mgmt
The "show log ap-debug" shows that it is unable to connect to device.arubanetworks.com:443. The error is:  Failed to establish SSL connection: Error code is -1:-188
Aruba
What release did you upgrade to?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
I am running 6.3.1.8-4.0.0.7_44641 right now.
