IAP (RAP Mode) - Split Tunnel Problem
I have an iap315 provisioned as rap to a 7005 controller.
I have two SSID's in that Rap Ap group.
When I set in split-tunnel fordwarding mode the web and app are not blocked/filtered.
Is the app/web filter/block possible in split-tunnel mode?
 How can i achive that?
grettings!
Re: IAP (RAP Mode) - Split Tunnel Problem
App and Web classification is done at the controller, so if the traffic hits the controller (tunneled, action:permit) it should work. If the traffic is switched locally (route-nat), it is not expected to work.
Ok. Thank you.
