IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
When there is same problem with Wireless Network, it is sometime needed to have same pcap trace for troubleshooting !
With new 802.11ac standard, there is no yet airpcap available for make pcap trace !
But with Aruba IAP, it is possible to use IAP for remote pcap ! with Wireshark (it is also possible with Aruba Controller !)
You need :
  • a IAP (recommanded IAP225, if you when sniffing 802.11ac)
  • a computer with Wireshark (> 1.11.3 !) available here
Connect to the IAP with SSH :
It is the same login and password like web administration page
Search the BSSID for access point using show ap monitor status command.
in WLAN Interface, there is the list of BSSID (one for 80211b/g and one for 80211/a/n/ac)
In my example, the BSSID is 24:de:c6:8b:12:20
Now use pcap command !
There is multiple argument in command
pcap start BSSID @IPofcomputer UDPPort format size
  • BSSID is the BSSID for IAP
  • @IPofcomputer is the address IP of computer with Wireshark
  • UDPPort is the UDP Port where the packet is send to the computer (use 5555)
  • format is the format of packet send to the computer (there is pcap, peek, airmagnet, pcap radio or ppi, see after for recommended value)
  • size the max size of packet (use 5000)
About format, actually airmagnet format is not yet support by Wireshark, it is recommended to use pcap for simple remote, if you need radio info use PPI or pcap radio format
The packet capture is start with id 5
Now launch Wireshark and go to the preference
Search Aruba ERM preferences
Set the UDP port configured in IAP (5555) and select also the format of captured packets (in my example, pcap (type 0))
and launch capture on your computer
You should be received all traffic from your network card, it is possible to filter the IAP traffic with following display fitler : udp.port==5555
You can now troubleshooting your wireless network :smileyvery-happy:
To display the list of pcap remote, you can use the following command :
show pcap status
for stop the capture, in SSH terminal, use the command :
pcap stop BSSID ID
Replace BSSID by the BSSID of IAP and ID by the id number of pcap capture (use show pcap status to found this number)
:smileyhappy:
ACMP 6.4 / ACMX #107 / ACCP 6.5
Frequent Contributor II
Re: IAP: Using remote pcap with #Wireshark #BMC #MAY-MHC
This looks promising but I'm not very familiar with IAP configuration, do you need to configure the IAP a specific way and how are you connected to the IAP?
Hi rosie
No specify configuration of IAP and my IAP is connected on my network... :-)
I'm assuming this can only be done if you are local to the location and not remote.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
I remember reading a post shared previously where the laptop was directly connected to the IAP running a specific code.
Here is the previous post: http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/AP-225-Sniffer/td-p/142005
Yes... but the capture is no in your computer ;-) (and it is possible to route the packet in your network !)
Trusted Contributor I
Great article! You helped solve an immediate need I had.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Lately I'm finding that when doing a capture from the controller port 5555 is denied in the datapath session table.  If you change the port to something like 162, it will get through to the wireshark client.
ACCP, ACCX #817, ACMP, ACMX #294
Strange,
No Uplink ACL on AP ? it is Campus or RAP ?
no uplink ACL.  It was a campus AP on 6.3.x
I saw on another post to use one of the standard ports (like 162) to 'trick' the controller into allowing it.
I did put this command in as well,
ap packet-capture open-port 5555
 but made no difference.  That gets added to the sys-ap-acl and my aps are using the ap-acl which I guess is why it got denied.
In any case, it was my lab controller, so maybe things got messed up with so many changes and upgrades/downgrades.  Main thing is I got it to work in the end.
:smileyhappy:
