IAP Vlan allocation through Clearpass
I need to configure IAP & clearpass to allocate vlan based on AD group. One SSID will be advertised & authentication is passed to AD.
Please advise about required configuration steps.
Re: IAP Vlan allocation through Clearpass
Hi, there is multiple steps to achieve this. If you review the following vidoes you should be able to ahcieve what you require.
https://youtu.be/BXa7zdbPU9c - ClearPass role assignment based on AD.
https://www.youtube.com/watch?v=9x5uvhn2pHg - 802.1x authentication on ClearPass with IAP.
https://www.youtube.com/watch?v=9x5uvhn2pHg - Join ClearPass to AD if using EAP-PEAP
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
You can also check out this video series: https://community.arubanetworks.com/t5/Security/Aruba-ClearPass-Workshop-Video-series/td-p/291597
It does exactly what you ask if you follow the 'Getting Started' and the 'Wireless' part.
