  • 1.  IAP and CAP?
    Posted Oct 30, 2016 06:39 PM
    We have an IAP cluster in a remote office that users are reporting issues with on a specific SSID. Typically on a campus controller deployment I can just point a CAP to it and troubleshoot. Is it possible to point another IAP or CAP in a differnet location to join with this cluster for troubelshooting? I assume if so just point it to the currrent IAP that is the master.
  • 2.  RE: IAP and CAP?
    Posted Oct 30, 2016 08:30 PM
    You'd need to have layer 2 connectivity between your lab IAP and the VC, probably better off grabbing the config and standing up a new IAP. At that point you can at least determine if it's a config issue, if it works fine in the lab then it points to the network / client.
  • 3.  RE: IAP and CAP?
    Posted Oct 30, 2016 09:36 PM
    Figured that was the case but wanted to make sure, appreciate it!
