Frequent Contributor II
Hi all, can someone shed some light on this ?
IAP 105 cluster, I want to use static vlan assignment for a number of SSID's.
So trunk the relevant vlans to the VC, will need to do this on all IAP's as the VC may fail.
When a client hits an ssid on a non VC ap does it GRE tunnel the traffic back to the VC as in a controller based solution ? ie do all clients ultimately need to hit the VC ?
Re: IAP and GRE
No!  The only time that the client's traffic will hit the VC is if:
1. You are using Virtual controller assigned for IP addressing
2. You are using IAP+VPN functionality on that VLAN
If it's just a static VLAN ID(s), then yhe traffic is dropped off locally on the APs wired port.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
