Frequent Contributor I
IAP not showing UP on Virtual Controller
[ Edited ]
We have 3 IAP's installed on same floor. whats happening is IAP hangs frequently i e the LED status will be good but cant able see those IAP in virtual controller and it will not broadcast also , after manual reboot of that  IAP we are able to see that in virtual controller.
I am attaching the Airwave logs for those IAP's
Please suggest me how to troble shoot.
Aruba
Re: IAP not showing UP on Virtual Controller
Can we get show log system from VC master when the issue occurs ?
Yesterday also we faced same issue.
As you requested we took the logs from virtual controller.
Please suggest me how to troble shooot this.
