IAP on 2 network
I have  2 diffrent network setup. I want to setup IAP for wireless. I need to know the config setup for setup seamless conectivity between the 2 network.
regards
Jayakumar
Re: IAP on 2 network
http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/L3_mobility/Configuring_a_mobility_d.htm
thanks for the support.
Can you explain the setup with a diagram for a better understatnding
regards
