Occasional Contributor I
IAP site survey mode
Hello guys,
Seems like this method from the url below, is not applied to the firmware of 6.3. The Wi-Fi won't broadcast if there is no uplink cable attached to the AP.
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Site-Survey-with-IAP-Manual/td-p/57274
Can someonne here correct me please?
Yeap
Super Contributor II
Re: IAP site survey mode
Sadly I think the IAP, by design, falls back to operating as a mesh device if it does not have an Ethernet link. I occasionally have to do site surveys and Its a real pain not being able to have a completely standalone Instant. All it would take would be a feature added to facilitate this. Maybe someone from Aruba follwing the forum could help facilitate this.
It can function without the uplink cable with a simple AC adapter.
When you say not applied to firmware 6.3? Are you referring to IAP version 4.0+?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Super Contributor I
I had used a loop back cable and it works.
Normal Guy
