Contributor I
IAP with VoWiFi
There is some tips/best pratice about using Instant Controller with VoWiFi (handset with SIP...) about roaming ? Filtering...
it is better to have a physical controller when use VoWiFi ?
Re: IAP with VoWiFi
If the VOWIFI device already marks traffic as voip, you are halfway there.  If it does not, the controller can mark the traffic, but QOS will only occur from the AP to the client.
Contributor I
Re: IAP with VoWiFi
It is not possible with IAP ? (for mark traffic)
Re: IAP with VoWiFi
Yes, but the IAP can only mark traffic from the AP to the client.  The client is responsible for marking the traffic from the client to the AP.
Re: IAP with VoWiFi
